edgarg37
Nov 13, 2021Tutor
DUMA OS App load issue
having this issue again it will not load please help: this happened again is there a permanent fix? I cannot open Device manager or QoS Error: This Rapp is not loaded yet, please try again in a m...
NetBulldog
Dec 21, 2021Aspirant
I have been living with DUMA OS App load issue for a year, I have tried everything referenced on this site and worked with customer support – nothing has worked. It looks like the only way to solve the issue is to purchase another brand of router. Which I will reluctantly be forced do soon if I do not find a solution.
michaelkenward
Dec 22, 2021Guru - Experienced User
NetBulldog wrote:
I have been living with DUMA OS App load issue for a year...
If you need help with DumaOS, follow the earlier advice in this ageing discussion and try the place where they discuss gaming routers.
Re: DUMA OS App load issue - NETGEAR Communities
