shaoo11's avatar
shaoo11
Follower
Jan 21, 2023
Duma OS Geo Filtering not working?
So I’ve recently got a Xbox series x and I’ve downloaded halo infinite. When I add the console on geo filtering halo infinite isn’t an option for the games so I have to press ‘choose manually’. When I play infinite nothing appears on the geo filtering ?? I’m not sure what I’m doing wrong?
1 Reply
  • Halo Infinite unfortunately doesn't work with the Geo-Filter, they took measures to disable Geo-Filtering completely (there did it because people were doing it on PC by changing game files and our Geo-Filter was an unfortunate casualty). You can follow these steps to see if it works just in case they changed something recently but otherwise unfortunately it won't work for the game.
    Quit the application/game/client completely
    Remove device from the Geo-Filter
    Resync from the Geo-Filter Map menu
    Re-add the device to the Geo-Filter with the manual option
    Set up the Geo-Filter how you like
    Wait 2 minutes
    Boot up application/game/client
    Then see if it works any better.
