Aaremm
Jul 03, 2019Tutor
DUMA OS issue on dashboard on xr500
how do i resolve this error?
- Jul 04, 2019
Hi Netduma_Alex,
I followed your instructions and presto, problem has been resolved.
Thanks for your advice, it was very appreciated.
Aaremm.
Netduma_Alex
Jul 03, 2019NetDuma Partner
If you go through the various DumaOS sections, every window has a little Pin icon in the top right. When the pin is filled in white, it's pinned to the dashboard. Could you go through every page of DumaOS (everything except Settings) and check for windows that are pinned? If any are pinned, unpin them. Hopefully whatever pin has glitched will be cleared.
You could also press F12 in Chrome to inspect the Dashboard and see if the broken window has a title in the "elements" section.
If worse comes to worst you might need to do a factory reset to clear the Dashboard.
Aaremm
Jul 04, 2019Tutor
Hi Netduma_Alex,
Aaremm.
