edgarg37
Mar 27, 2021Tutor
Duma OS Issue
I am still having Isuses with my gaming router i cannot get into any of the Tabs QOS, Device Manager, Network Monitor, or Hybid VPN. Its been like this for months. below is the error i keep getting. ...
Netduma-Fraser
Mar 27, 2021NetDuma Partner
What firmware are you currently using? What device/web browser are you using to access the router?
- edgarg37Mar 27, 2021Tutor
the current firmware is V2.3.2.56 and i am using a MackBook -browser is Safari worked fine when i first got the router now its been down for months
- Netduma-FraserMar 27, 2021NetDuma PartnerI'd recommend upgrading to the latest beta firmware and then doing a factory reset and it should work https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196/jump-to/first-unread-message
ok how is this done? the link just takes me to a thread with 178 comments
