thewizzzrd
Mar 09, 2021Tutor
duma os won't load on my pc
This is the second time in 3 days this problem has occurred. The dumaos will not load. The first time I contacted support over the phone they had me do a complete reset of the router. I do not want t...
Netduma-Fraser
Mar 09, 2021NetDuma Partner
Could you provide a screenshot of exactly what you're seeing please? Is it the entire interface or specific pages?
- thewizzzrdMar 09, 2021Tutor
- Netduma-FraserMar 09, 2021NetDuma PartnerIt looks like you have a VPN active on the browser, you will need to disable that and then you will get access
- thewizzzrdMar 09, 2021TutorI disconnected the VPN in windows under network & security and on my browser. It still won't open
