thewizzzrd
Mar 09, 2021Tutor
duma os won't load on my pc
This is the second time in 3 days this problem has occurred. The dumaos will not load. The first time I contacted support over the phone they had me do a complete reset of the router. I do not want t...
thewizzzrd
Mar 09, 2021Tutor
Netduma-Fraser
Mar 09, 2021NetDuma Partner
It looks like you have a VPN active on the browser, you will need to disable that and then you will get access
- thewizzzrdMar 09, 2021TutorI disconnected the VPN in windows under network & security and on my browser. It still won't open
- Netduma-LiamMar 10, 2021NetDuma Partner
Are you seeing the same issues across all browsers? Could you perhaps try an incognito window?
- thewizzzrdMar 10, 2021Tutor
yes all browsers
not sure how to
