XR700-Owner's avatar
XR700-Owner
Apprentice
Sep 03, 2022
DumaOS 3.0 Release for XR700
So all of the DumaOS related forums have been closed and we can't reply on them anymore.  We were told multiple times from NetDuma that there was a 3.0 coming for release and that they had a "new system" as how they created and tested new FW. This new system would magically make the process so much faster.  Now the XR700 is one of the only NetDuma machines still running the 2.0 platform while every other NetDuma machine already has 3.0 and is in the process of getting 3.2.  After waiting all this time for DumaOS 3.0 final release, NOW we have to wait for the XR500 to get DumaOS 3.2 before we even get 3.0?  This is very unprofessional as we've been waiting years for 3.0 as a final release.  I get the response "Well we use the XR500 for our dev router so we're working on 3.2 for that now then porting over to the XR700".  If it was a simple port over (which from other closed forums it's NOT a simple port over) we would have had 3.0 on the XR700 shortly after the XR500.  So why is NetDuma giving us XR700 owners the run-around and double talk?  The R1 and R2 have 3.0. the XR500 and 1000 have 3.0.  Even their "Smart Modem" line all have DumaOS 3.0.  I honstely want to know why NetDuma chose to put the XR700 in the closet and work on upgrading every other piece of hardware TWICE before giving DumaOS 3.0 to the XR700.
  • None of the forums have been closed, they're all still open and able to be replied to. I understand you are frustrated but we are working on it, outside the link above there isn't any more information we can provide about the status of updates. The R1 basically has an Open Beta of 3.0, same with the 700. R2 got it first I believe, then the 500 was in beta for awhile and the 1000 had it pretty much from the start. Different platforms require differing amounts of work hence why they're at a different stage. Given 3.2 was already being worked on it would take more time to go back and put a full stable version of 3 on the 700. 3.2 is the firmware we plan to almost unify the platforms with so they're all at a relatively similar level.
    • XR700-Owner's avatar
      XR700-Owner
      Apprentice
      What's up Frasier! First, I can't reply on any of the other xr700 dumaos 3.0 forums so there's that. I'm not sure why but at least now I know others can reply. So why is it I can't reply on the forums I used to be able to? Second, why did NetDuma decide to start work on 3.2 when not all the machines even have 3.0 yet? Lastly, why say after 3.2 is written for the xr500 (because it's the dev router) it'll simply be ported over as you've started before it's not as easy as a simple port over? I just don't understand the logic of any of it.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Are you referring to this forum? https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Beta/bd-p/en-home-beta-firmware-npg If so it hasn't been used in a very long time so might be they've shut it done for a little while given it's not running a 'current' beta firmware. We are always iterating, we have multiple devs who work on different aspects some of which will go into 3.2 while others work on more current problems etc. We have to get the core of 3.2 sorted first, trying to literally build it on each platform would be counter intuitive, it's easier to port to different platforms than it is to build on each one separately.
