Mike40
Apr 11, 2024Luminary
DumaOS is loading... This could take up to four minutes. Please wait.
Issue #1 I unplugged my CM1200 modem and my XR500 router two days ago. I waited a minute then plugged them back in. Since then I have kept getting the following message on my PC DumaOS is loading...
- Apr 13, 2024You can select win32 from here https://github.com/jclehner/nmrpflash/releases/tag/v0.9.22
Apr 11, 2024Guru - Experienced User
What browser are you using?
What firmware version is loaded?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Mike40
What browser are you using? As stated above, I have tried Chrome and Firefox.
What firmware version is loaded? I'm 99.9% sure it's 2.3.2.134. I can't look though unless I factory reset the router yet again and see if it tells me on my phone.
These are the CAT6 cables that I use.
https://www.amazon.com/gp/product/B086H88T9W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Here is the event log. If you can't see the screenshot, please let me know.
- FURRYe38Apr 11, 2024Guru - Experienced User
Please post the cable connections data page as well.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
