Mike40
Apr 11, 2024Luminary
DumaOS is loading... This could take up to four minutes. Please wait.
Issue #1 I unplugged my CM1200 modem and my XR500 router two days ago. I waited a minute then plugged them back in. Since then I have kept getting the following message on my PC DumaOS is loading...
- Apr 13, 2024You can select win32 from here https://github.com/jclehner/nmrpflash/releases/tag/v0.9.22
Netduma-Fraser
Apr 11, 2024NetDuma Partner
Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
- Mike40Apr 11, 2024Luminary
How do I do this? I do not see this in the app version and I can not access DumaOS on anything else.
- Netduma-FraserApr 11, 2024NetDuma PartnerYou wouldn't be able to do it on the app. Probably best to do a factory reset if you can never regain access via a reboot and then do it
- Mike40Apr 11, 2024LuminaryI've already done a factory reset about 5 times and it doesn't help anything other than wasting about 10 minutes setting everything up.
