Mike40
Apr 11, 2024Luminary
DumaOS is loading... This could take up to four minutes. Please wait.
Issue #1 I unplugged my CM1200 modem and my XR500 router two days ago. I waited a minute then plugged them back in. Since then I have kept getting the following message on my PC DumaOS is loading...
- Apr 13, 2024You can select win32 from here https://github.com/jclehner/nmrpflash/releases/tag/v0.9.22
Mike40
Apr 13, 2024Luminary
Which one should I download? I'm using Windows 11.
Netduma-Fraser
Apr 13, 2024NetDuma Partner
- Mike40Apr 14, 2024Luminary
After doing the nmrpflash, unplugging the modem and router, it FINALLY works again.
Thanks dude. I appreciate it 🙂
- Netduma-FraserApr 15, 2024NetDuma PartnerThat's great to hear, thanks for the update!
