WhatitDo
May 24, 2020Aspirant
DumaOS keeps crashing and not finding Router
3.2.56 is software patch, its about 1 month old. It filters the internet but Duma Os is not found i have to reset the router from the app and it will find it be fine for 3 to 5 hours and if i check i...
May 26, 2020Guru - Experienced User
Please downgrade the FW
Firmware Version 2.3.2.40 or
Firmware Version 2.3.2.32
Netduma-Fraser
May 26, 2020NetDuma Partner
Are you accessing via routerlogin.net or the LAN IP? If the former try the LAN IP and see if you get the same issue.
- WhatitDoMay 26, 2020Aspirant
its the same on both wont let me log on, goes to netgear showing how to clear cache
Netduma-Fraser wrote:
Are you accessing via routerlogin.net or the LAN IP? If the former try the LAN IP and see if you get the same issue.- FURRYe38May 27, 2020Guru - Experienced User
Press the reset button in back for 15 seconds then release. Connect 1 wired PC to the back of the XR router. Use FireFox or Opera browser and input 192.168.1.1 into the browser. Can you walk thru the setup wizard here and complete the setup? Be sure to write down all important information seen in the setup wizard.
- Netduma-FraserMay 27, 2020NetDuma PartnerYou shouldn't get that redirection by accessing via the LAN IP, could you provide a screenshot of what you're seeing when it's not working through the LAN IP please?
