eddie1590
Aug 07, 2023Follower
DumaOS not loaded yet! XR700 (no 2.4 or 5ghz wifi either)
Hello, For the past week I have not been able to log-in to my routers dashboard through the web. I keep getting a message stating: “DumaOS not loaded yet! Don’t worry we will redirect you shortly”. I...
jameshatt
Aug 08, 2023Aspirant
It seems like you're experiencing issues with your XR700 router, specifically with DumaOS not loading and the absence of 2.4GHz and 5GHz WiFi signals. Here are some troubleshooting steps you can take to address these problems:
1. Power Cycle the Router:
- Unplug the power adapter from the router.
- Wait for about 10-15 seconds.
- Plug the power adapter back in and let the router boot up. This can often resolve minor software glitches.
2. Factory Reset:
- Use a small, pointed object (like a paperclip) to press and hold the reset button on the back of the router for about 10 seconds.
- Release the button and wait for the router to reset. This will revert the router settings to their default values. Note that you'll need to reconfigure your router settings after a factory reset.
