zenom
Apr 12, 2018Aspirant
DumaOS not loaded yet!
When I first configured the router, the DumaOS url would load, now it does not load at all. I can get to /adv_index.html for the old netgear config, but the DumaOS stuff is not loading. I have tried ...
Netduma-Fraser
Apr 12, 2018NetDuma Partner
Is this showing on a white screen? What occurred to get you to that point? If you do a factory reset that will resolve the issue.
zenom
It just started happening, I haven't done a factory reset yet, but yes, its a white screen.
- Netduma-FraserApr 12, 2018NetDuma PartnerWas there any setting you changed prior to this?
- zenomApr 12, 2018Aspirant
I had not touched the router in weeks, then all of a sudden, it started happening.
- Netduma-FraserApr 12, 2018NetDuma PartnerOkay well factory reset to fix it and then let us know if you notice it happen again and if there was anything that happened beforehand please
