Mitja1980
Dec 14, 2018Initiate
DumaOS not loaded yet!
I have updated my XR500 to the latest firmware V2.3.2.40. After the update the DumaOS url does not load at all. I have tried rebooting, factory reseting r...
Netduma_Jack
Dec 15, 2018NetDuma Partner
That’s strange. It sounds like the install did not complete successfully.
I recommend you downgrade back the previous firmware. Check that all is working. And then try upgrading again.
I imagine you cannot access the interface like normal, so instead, use this link to get to the settings section: http://routerlogin.net/adv_index.htm
From there go to Administration and Firmware update and install the previous firmware.
http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip
