3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
 For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message.  DumaOS not loaded yet!  Any idea whats going on?
3791eidde
Dec 17, 2019Tutor
I did a reset, I get the same issue when I try to login. I had this router running for about a year with no issues. All the sudden today I got this issue.
- Netduma-FraserDec 17, 2019NetDuma PartnerDoes this occur for the entire interface i.e. you can't access any page or is it on specific pages it happens? In System Information on the R-App panel options change the number of retries to 5 instead of 3 and then reboot the router please and see if that helps. What is your firmware version?- 3791eiddeDec 17, 2019TutorThis happens after login. I am unable to go to any pages. I am on the latest firmware. Did a factory reset and there was no updates. - HilockDec 17, 2019InitiateHi, I have the same problem today. The router works correctly but it's impossible to log in. I have try a downgrade but the pb stay the same.
