3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
 For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message.  DumaOS not loaded yet!  Any idea whats going on?
Netduma-Fraser
Dec 17, 2019NetDuma Partner
Does this occur for the entire interface i.e. you can't access any page or is it on specific pages it happens? In System Information on the R-App panel options change the number of retries to 5 instead of 3 and then reboot the router please and see if that helps. What is your firmware version?
3791eidde
Dec 17, 2019Tutor
This happens after login. I am unable to go to any pages. I am on the latest firmware. Did a factory reset and there was no updates.
- HilockDec 17, 2019InitiateHi, I have the same problem today. The router works correctly but it's impossible to log in. I have try a downgrade but the pb stay the same. - IssuesabundantDec 17, 2019Aspirantsame issue not loading either.
