3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
 For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message.  DumaOS not loaded yet!  Any idea whats going on?
Dr_Evil_Genius
Dec 17, 2019Initiate
I'm reporting the same issue. Both myself and my friend living across the country logged onto PSN and got the same exact problem.
We used this workaround:
1. http://routerlogin.net/adv_index.htm
2.Administration -> Firmware Update
3. http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip
4. Unpack the .zip file
5. Browse to Image file
6. Upload
This got our XR500s working for now. I hope this helps and I hope this issue gets a permanent solution soon.
- 3791eiddeDec 17, 2019TutorThank you for that. - Netduma-FraserDec 17, 2019NetDuma PartnerThank you Dr_Evil_Genius for that workaround. It seems a few people have experienced this today, I have raised this with our team so we will investigate this ASAP. If you're having issues please follow that workaround.
- HilockDec 17, 2019Initiate
 Dr_Evil_Genius wrote:I'm reporting the same issue. Both myself and my friend living across the country logged onto PSN and got the same exact problem. We used this workaround: 1. http://routerlogin.net/adv_index.htm 2.Administration -> Firmware Update 3. http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip 4. Unpack the .zip file 5. Browse to Image file 6. Upload This got our XR500s working for now. I hope this helps and I hope this issue gets a permanent solution soon. Thanks, the problem was solved. I stop the auto update to keep this Firmware
