3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message. DumaOS not loaded yet! Any idea whats going on?
Slurps
Dec 17, 2019Initiate
Same issue here. Been scratching my head all day about this, but I'm about to downgrade the firmware myself to resolve the issue as it seems this is a fix according thos this forumn and a few others I checked out.
- Netduma_JackDec 17, 2019NetDuma Partner
Hi - it should now be fixed actually, so instead of downgrading could you try rebooting your router instead (i.e. turn it off and then back on again). Please let us know if that fixes your problem
- Netduma-FraserDec 17, 2019NetDuma PartnerPlease see the fix I posted above, it should just require you to do a reboot if you're on the current .56 firmware.
- SlurpsDec 17, 2019Initiate
Sorry didn't read the post above me. Restarting router now to try and see if it's all fixed before I downgrade
- BonkeydaveDec 18, 2019Aspirant
I have returned from a business trip to this issue, reboot of router does not fix the issue
- burDec 18, 2019Tutor
Same issue.
XR500 with firmware version: V2.3.2.56 running from year without any issue.
Then yesterday 2019 Dec 17 DUMAOS FAILED TO BE LOADED.
Resolved using
1. http://routerlogin.net/adv_index.htm
2.Administration -> Firmware Update
3.Router Auto Firmware Update -> I Disagree
Hope there is no issue with DUMAS Web service as a lot log available like :
[DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Wednesday, December 18, 2019 11:59:55
