3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message. DumaOS not loaded yet! Any idea whats going on?
Slurps
Dec 17, 2019Initiate
Sorry didn't read the post above me. Restarting router now to try and see if it's all fixed before I downgrade
Bonkeydave
Dec 18, 2019Aspirant
I have returned from a business trip to this issue, reboot of router does not fix the issue
- burDec 18, 2019Tutor
Same issue.
XR500 with firmware version: V2.3.2.56 running from year without any issue.
Then yesterday 2019 Dec 17 DUMAOS FAILED TO BE LOADED.
Resolved using
1. http://routerlogin.net/adv_index.htm
2.Administration -> Firmware Update
3.Router Auto Firmware Update -> I Disagree
Hope there is no issue with DUMAS Web service as a lot log available like :
[DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Wednesday, December 18, 2019 11:59:55 - BonkeydaveDec 18, 2019Aspirant
2 reboots later and i can now login properly. However now none of the R-Apps will load.
Regardless of being able to log in something is certainly not happy...
- Netduma_AlexDec 18, 2019NetDuma Partner
I would reccomend downloading this firmware: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Then go to http://routerlogin.net/adv_index.htm
Go to administration, firmware update, and upload the file you downloaded.
Now you can upgrade back to the current version again.
This was caused by a temporary issue with our servers, apologies.
