3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message. DumaOS not loaded yet! Any idea whats going on?
dan801
Dec 22, 2019Apprentice
Same issue here since yesterday. Mulitple re-starts same issue. Last option is Reset which I'm not keen on.
- burDec 22, 2019Tutor
Hi Dan801
try :
1. http://routerlogin.net/adv_index.htm
2.Administration -> Firmware Update
3.Router Auto Firmware Update -> I Disagree
- Netduma-FraserDec 24, 2019NetDuma Partnerdan801 you most likely just need to delete the cache/cookies on your web browser and then you will be able to access the interface.
