SouthernGypsy
May 06, 2024Apprentice
DumaOS on XR1000v2 Keeps Kicking Me Out?
This is a multi-part question so bear with me while I explain this bizarre behavior, which isn't always the same exact bizarre behavior each time which makes it very difficult to figure out the cause...
May 06, 2024Guru - Experienced User
What FW version is loaded on the router?
Does this happen with a different web browser, like MS Edge?
Be sure your clearing out the web browser cache before entering the routers web page.
This happen if you use the routers IP address in stead?
I haven't seen issues like this on mine, however mine is a v1. I use MS Edge alwasy when I configure my XR1000.
- SouthernGypsyMay 06, 2024Apprentice
I don't know since I don't use other browsers, I only have Firefox loaded.
Thought I had mentioned it but guess I forgot, it's the Newest firmware version 1.1.0.16_2.1.25
Yes, it also does the same thing if you log in with the routers IP address, just everything is reversed, you can then SOMETIMES use the routerlogin.net/ to log in and sometimes not. So it does not matter which way you log in, it can happen either way.
Are you asking if I have tried clearing out the web browser cache? Yes, but I don't do it everytime. Like restarting computer that usually will let me back in, but obvioulsy I should not have to go through all the trouble to clear my browser everytime I want to load this thing. Plus whenever I do that, it makes me have to close the "tutotial" things that then pop up again every time on every page in the DumaOS menus.
Oh, I have also tried whitelisting both the routers IP addtress and the routerlogin.net/ addresses in my browser but that didn't help change anything either. That was the first thing I tried when it happend the first night I had it.
- Netduma-FraserMay 07, 2024NetDuma PartnerIt's a difficult one because there are absolutely no settings for the timeout/login past changing the password. Are you trying to access via HTTPS or is the browser forcing HTTPS by any chance? You may have better luck forcing HTTP which is what should be used for best performance.
- SouthernGypsyMay 07, 2024Apprentice
You just said the same thing (https://) twice but I assume you meant one of them to be http:// and mine just always says https:// but after reading your message I tried manually typing http:// and it instantly reverts to https://
How do I go about "forcing" http:// like you mentioned when it seems determined to switch to https:// ...?
