bread941
Jan 08, 2021Tutor
DumaOS Traffic Prioritisation
Does traffic prioritisation work with QoS disabled? It definitely still detect the high priority traffic, as indicated by the red light but I was wondering if it still applies that prioritisation...
- Jan 09, 2021If you use Bandwidth Allocation on default then it basically isn't doing anything so you can ignore that. You need to re-enable QoS from the Anti-Bufferbloat menu, then select Never on Anti-Bufferbloat. Traffic Prioritization will then work.
bread941
Jan 09, 2021Tutor
So does make it so that it doesn't use the graph where you allocate download and upload bandwidth for each device?
And if I disable QoS through the buffer bloat, it doesn't count the prioritised packets, it stay on zero. So is it definitely still working even though it doesn't count them? Sorry, I'm confused
Netduma-Fraser
Jan 09, 2021NetDuma Partner
- bread941Jan 09, 2021TutorAhhh, that's great. Thank you so much. <3
