Elphara
Jan 01, 2019Aspirant
DumaOS XR700 Does not launch Device Manager section or R-Apps even after reset factory Please Help
Jan 01, 2019Guru - Experienced User
Try FF or Opera browsers to see if this happens...
- Netduma_JackJan 02, 2019NetDuma Partner
Hi - how are you factory resetting? Make sure you're doing a full reset, not just a router reboot: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
Also make sure you clear your cache as that could be causing the problem (press Ctrl + F5 when on the Device Manager)
- ElpharaJan 09, 2019AspirantYes it looks better on Firefox but now it goes on MS Edge
- Netduma-FraserJan 09, 2019NetDuma PartnerA new version has been released, please see if that resolves your issue: https://kb.netgear.com/en_US/000060499/
