mrekimf
Apr 06, 2019Apprentice
Dumas OS Device manager
In reference to the Duma OS Device manager, its showing devices not connected(wirelessly) even though they are connected.
Also, can you not control when new devices connect to internet? Like I use ...
Netduma_Jack
Apr 09, 2019NetDuma Partner
Hi there - there's currently no pre-emptive blocking (ACL), but we will look to add this in the future.
Also, how are these online devices appearing as offline connected to your router? Are they through an extender/switch, or directly connected?And what type of devices are they?
mrekimf
Apr 09, 2019Apprentice
As for the items showing OFFLINE, they are just from the router,no switches or anything else, they are connected through wifi, items like a laptop and xbox, both are being used at time of checking connection, there not idle they are actually being used.
- Netduma_JackApr 10, 2019NetDuma Partner
On ACL - I think it was possibly due to a conflict between NETGEAR's software and the new Device Manager. We will aim to add this feature in the near future.
As for these offline devices, that's definitely odd. One thing to double check is there isn't another device with the same name showing as online? If you connect the same device over wired and then over Wifi, it will have two different devices in the Device Manager because the MAC address of the network adapters are different.
If it's not that, then could you try downgrading back to the previous firmware and see if that fixes the problem: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
