mrekimf
Apr 06, 2019Apprentice
Dumas OS Device manager
In reference to the Duma OS Device manager, its showing devices not connected(wirelessly) even though they are connected.
Also, can you not control when new devices connect to internet? Like I use ...
Netduma_Jack
Apr 15, 2019NetDuma Partner
If you try downgrading back to .32 it may be resolved there. Could you try this please?
mrekimf
Apr 15, 2019Apprentice
I would need help on how to do this.
thank you
- Netduma_JackApr 16, 2019NetDuma Partner
No worries, here's the .32 firmware: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Instructions on how to install are on that page too.
- mrekimfApr 17, 2019Apprentice
Well it helped. But still showing my laptop still offline, which is what I am on right now.
Also, is there a way to downgrade the Android Genie App, cause of course it says "update" but its not showing any devices connected
thanks
- Netduma-FraserApr 18, 2019NetDuma PartnerYou might need to do a reboot or factory reset after the downgrade and your laptop should then show correctly. That's app is solely Netgears so wouldn't know the answer to that unfortunately.
