Renovatio_Nixie
Nov 02, 2021Tutor
DumasOS not loaded yet
Hello, I have recently purcahsed Nighthawk XR1000 pro gaming router. After one month when i trying to login into the router settings I am getting error 'DumasOS not loaded yet'. I did clear brows...
Nov 03, 2021Guru - Experienced User
Does everything else still work?
Try firefox.
I notice you have a 10.0.0.1 address.
what's the xr1000 connected to for modem/gateway?
Renovatio_Nixie
Nov 03, 2021Tutor
Yes everything is working. I am able to access net through wifi. Tried Mozilla, Edge, Opera but still shows the same error. Earlier I was able to access the router settings but now it gives the error DumasOS not loaded yet. No modem nothing direct connection from ISP.
- plemansNov 03, 2021Guru - Experienced User
Have you tried a simple factory reset?
- Renovatio_NixieNov 03, 2021Tutor
Factory reset is the last resort. I have already setup the router settings and its time consuming to do those settings again. If everytime we have to do factory reset then what is the use ???.
- FURRYe38Nov 03, 2021Guru - Experienced User
You can save off a back up configuration before you reset. There is a reason why NG out that in there FW. Saves time if a reset is needed.
