Renovatio_Nixie
Nov 02, 2021Tutor
DumasOS not loaded yet
Hello, I have recently purcahsed Nighthawk XR1000 pro gaming router. After one month when i trying to login into the router settings I am getting error 'DumasOS not loaded yet'. I did clear brows...
Renovatio_Nixie
Nov 03, 2021Tutor
Yes everything is working. I am able to access net through wifi. Tried Mozilla, Edge, Opera but still shows the same error. Earlier I was able to access the router settings but now it gives the error DumasOS not loaded yet. No modem nothing direct connection from ISP.
Nov 03, 2021Guru - Experienced User
Have you tried a simple factory reset?
- Renovatio_NixieNov 03, 2021Tutor
Factory reset is the last resort. I have already setup the router settings and its time consuming to do those settings again. If everytime we have to do factory reset then what is the use ???.
- FURRYe38Nov 03, 2021Guru - Experienced User
You can save off a back up configuration before you reset. There is a reason why NG out that in there FW. Saves time if a reset is needed.
- Renovatio_NixieNov 04, 2021Tutor
So the only solution I get from Netgear team is factory reset. Good Good. So everytime anyone of us gets the error of 'DumasOS not loaded yet' is factory reset great!!!. So we need to save the router setting backup files and do factory reset. But the simple firmware update from Netgear team is not possible.... Hilarious.
