Mark9816
Jul 22, 2020Apprentice
eaithernet port speed
I have been getting diffrent color lights on the front of the router for my pc and PS4 Pro. I went in to the router and for some reason my pc is showing 100mg and the PS4 shows 10000mg why??? The rou...
- Jul 22, 2020
Problem solved I got a USB 3.0 gbt ethernet adaptor and it solved the problem.
Mark9816
Ive tried diffrent cables and it did nothing changing ports on the router did nothing. So I guess its the pc then. Thanks
Netduma-Fraser
Jul 22, 2020NetDuma Partner
Check your PC ethernet/wifi adapter, you may be able to change the link speed to 1000mbps - it may be limited by settings or the adapter itself is not capable.
- Mark9816Jul 22, 2020Apprentice
Thank you I will look in to that because I just know it used to have to white lights on, on the front of the router one for ps4 and one for pc and now only the ps4 gets a white light and the router says what it says on the dash board but with all the updates to windows 10 who knows if some thing got changed by an update. But being a labtop who knows if its just a 100mg port but it should of allways been a oreange light and it was not. Thank you all for the help on this issue.
