KapoArsenaly
Jul 19, 2024Tutor
Efootball geo filter not supported in xr1000
How can i benefit from the router if my favourite game isn't supported ?? How can i run geo filter .
Netduma-Fraser
Jul 19, 2024NetDuma Partner
How are you determining it isn't supported exactly? You should be able to add it as an option on the Geo-Filter if using the PC or if you're on console you can just filter it as is
- KapoArsenalyJul 19, 2024TutorIt isn't in the list of games so i forced to choose unreal engine.
- Netduma-FraserJul 19, 2024NetDuma PartnerWe may need to do a cloud update then, you can still switch it to use filtering mode and it will work. Alternatively, remove the device from the Geo-Filter, change the PC to a PlayStation in the Device Manager and then re-add it to the Geo-Filter with the manual option and you can filter then.
- KapoArsenalyJul 19, 2024TutorThank thank thank u maaan ❤️🙏
