KapoArsenaly
Jul 19, 2024Tutor
Efootball geo filter not supported in xr1000
How can i benefit from the router if my favourite game isn't supported ?? How can i run geo filter .
KapoArsenaly
Jul 19, 2024Tutor
It isn't in the list of games so i forced to choose unreal engine.
Netduma-Fraser
Jul 19, 2024NetDuma Partner
We may need to do a cloud update then, you can still switch it to use filtering mode and it will work. Alternatively, remove the device from the Geo-Filter, change the PC to a PlayStation in the Device Manager and then re-add it to the Geo-Filter with the manual option and you can filter then.
- KapoArsenalyJul 19, 2024TutorThank thank thank u maaan ❤️🙏
