WacoJohn's avatar
WacoJohn
Luminary
Jul 19, 2018
Ejecting USB Hard Drive xr500
I have a USB 3.0 drive connected to my xr500 router.  It works perfectly on my home network.  I need to eject it, do a quick format on it, and reconnect it.  When I connected it the first time, I had...
  • Netduma-Fraser's avatar
    Jul 20, 2018
    More than likely you would need to go through setup again as it would be like connecting a different USB to the router for the first time.
