WacoJohn
Jul 19, 2018Luminary
Ejecting USB Hard Drive xr500
I have a USB 3.0 drive connected to my xr500 router. It works perfectly on my home network. I need to eject it, do a quick format on it, and reconnect it. When I connected it the first time, I had...
- Jul 20, 2018More than likely you would need to go through setup again as it would be like connecting a different USB to the router for the first time.
WacoJohn
Jul 20, 2018Luminary
I was afraid of that. I have only done it the one time ... and even that was with tech support on the phone. I am not sure I remember exactly how. I guess I will have to find something in the user guide or online. If you can refer me to a tutorial .. that would be great. Thank you for the reply, and I will close thread as solved on your next reply. Thank you again.
Netduma-Fraser
Jul 20, 2018NetDuma Partner
You might be okay if you recreated the USB folder. Setup would depend on which USB feature you're using. I don't have any guides specifically, I'm not too familiar with the feature as it's a Netgear own feature
- WacoJohnJul 20, 2018Luminary
I will have to just pull the trigger and see what happens. It may come back to me. Oddly, . I found a 'help' item that said simply plug in the drive and wait. Then it asked me if this was helpful.
Anyway ... thank you both for your time and attention.
