Pipodi
Jul 22, 2022Tutor
Enable Traffic Prioritization on Escape From Tarkov
Hi guys, I've just bought an XR1000 and I'm loving it so much. I've set up pretty much of the QoS as I want following the wizards. But I can't find guides/sources on how to prioritize games like ...
Netduma-Fraser
Jul 22, 2022NetDuma Partner
For Traffic Prioritization if it doesn't have your game listed you can make rules for the ports the game uses, you should be able to find the ports it uses online and then you can make the rules. We haven't specifically tested the game which is why it is hit and miss, when you see that Battleye server add it to your allow list and see if it filters more consistently.
- PipodiJul 23, 2022Tutor
I don't know why my replies are not posted, am I moderated or what?
- Netduma-FraserJul 23, 2022NetDuma PartnerI can see you've made 5 posts in total but I can't see what the other 3 are so I'm not sure what happened there. Can you repost what you said previously?
- PipodiJul 25, 2022Tutor
Nothing, it seems I can't post anything...
