Pipodi
Jul 22, 2022Tutor
Enable Traffic Prioritization on Escape From Tarkov
Hi guys, I've just bought an XR1000 and I'm loving it so much. I've set up pretty much of the QoS as I want following the wizards. But I can't find guides/sources on how to prioritize games like ...
Pipodi
Jul 23, 2022Tutor
I don't know why my replies are not posted, am I moderated or what?
Netduma-Fraser
Jul 23, 2022NetDuma Partner
I can see you've made 5 posts in total but I can't see what the other 3 are so I'm not sure what happened there. Can you repost what you said previously?
- PipodiJul 25, 2022Tutor
Nothing, it seems I can't post anything...
I've created a rule in traffic prioritization using a port range found on the official forum, I started a game and no red light on the entry. I'm sure that the server port is in the range because I can see it in the game logs. The source range is all the available ports, UDP protocol.
- Netduma-LiamJul 25, 2022NetDuma Partner
Could you please attach a screenshot of your rule so we can see if there's anything that needs changing? I'd suggest attaching the image as an attachment rather than pasting it in so we don't have wait for it to be moderated.
