Pipodi
Jul 22, 2022Tutor
Enable Traffic Prioritization on Escape From Tarkov
Hi guys, I've just bought an XR1000 and I'm loving it so much. I've set up pretty much of the QoS as I want following the wizards. But I can't find guides/sources on how to prioritize games like ...
Netduma-Liam
Jul 26, 2022NetDuma Partner
Does the PC have a Wi-Fi adapter or any other interfaces? If so, can you please disable them to ensure that traffic is only going through the R2 and nowhere else.
Pipodi
Jul 26, 2022Tutor
Ok, your answer got me thinking. I went into Device Manager and I saw 2 devices with the same IP as my PC. I removed them and reassigned them the IP. Now the original prioritization rule works flawlessly with EFT.
- Netduma-FraserJul 26, 2022NetDuma PartnerGreat to hear that, thanks for the update/solution!
