moski247
May 16, 2022Tutor
error device not found / QOS xr500 V2.3.2.134
getting a error code for device not found for the traffic priority app in QOS setting anything i can do to fix the problem.. thanks
moski247
May 16, 2022Tutor
factory rest completed in the process it reverted to a older firmware and updated to current v.134. after updated and set up wizard. I unpluged the router and power cycled the router.
still have missing device error..
Netduma-Fraser
May 16, 2022NetDuma Partner
Could you clarify what you mean exactly, did you factory reset before or after updating to .134?
- moski247May 18, 2022TutorI updated the router to v2.3.2.134 about a month before I noticed the error.
I contact support, was recommended to factory reset, I did the factory reset. Once completed I was sent to the wizard for internet and WiFi set up
After completing the wizard set up. The router automatically Search for an update. V2.3.2.134 was available, so I accepted the update. Once completed I clicked QOS tab same error poped up. I then turned off the router and unplugged it for 30 seconds to power cycle and refresh the machine. Reconnect. Went to QOS tab clicked and got the same error.
Appreciate your help- Netduma-LiamMay 18, 2022NetDuma Partner
I believe what you'll need to do in this case is to downgrade to the latest previous firmware, factory reset when on that firmware, then re-upgrade to the latest. You don't need to factory reset again after that. That should solve the problem for you.
- cezareSep 02, 2022Aspirant
dear Admin this is not a solution.
i spend hours to find one....
that is the real fix.
recovery mode.
1.Turn off the power, push and hold the reset button (in a hole on
backside) with a pin
2.Turn on the power and wait till power led starts flashing white
(after it first flashes orange for a while)
3.Release the reset button and tftp the factory img in binary mode.
The power led will stop flashing if you succeeded in transferring
the image, and the router reboots rather quickly with the new
firmware.
Uploading the firmware image with a TFTP client
use the command :tftp -i 192.168.1.1 put XR500-V2.3.2.134.img
and finally, I get the confirmation " Transfer successful: 38529153 bytes in 4 second(s), 9632288 bytes/s"
then, everything works as should be ..
