David_Antunes
Apr 13, 2019Aspirant
Error Mac address and Ports
Hello i have same manufacture bugs with my xr500.
The 1 is my MAC ADDRESS:
On the back of my router the mac end with :78 on my windows is the same
The 2 is my ports i have active port 4...
schumaku
Apr 13, 2019Guru - Experienced User
Same as ...?
Nothing wrong:
- The MAC address printed on the label is the one for the LAN interface, so the same .78 you see on the connected clients.
- The MAC+1 is the Internet/WAN interface MAC address.
The 2 is my ports i have active port 4 and the led is on but in the duma os th uses port 1
Current firmware?
- David_AntunesApr 13, 2019Aspirant
It is not "same" but some.
My mac address it is not the same printed on the back of my router and the mac address onduma os software.
XR500 V2.3.2.40
- schumakuApr 14, 2019Guru - Experienced User
You said printed and on Windows it shows :78 (this is the LAN interface MAC) while the :79 you see on the Internet screenshot is one higher as expeced - so again, perfectly right.
- Netduma_JackApr 15, 2019NetDuma Partner
Was there anything specific you were trying to achieve here that we can help you with?
