Rauko
Oct 25, 2021Guide
Error: Missing JSON response.
A window with the message Error: Missing JSON response. keep popping randomly. its not the product of any interaction with the UI, it just randomly pops every now and then, really annoying.
- Feb 16, 2022
In may case, and after a million different approaches, the solution seamed to be forcing the router an Rx300 to use a 192 based IP. on setup it always auto changed to a 10 based IP not to conflict with my network. I let it do it but I imediatly log via de http://routerlogin.com/adv_index.htm address and change it to 192. It has been workign just fine for now.
In any case, since Im here I have a rather offtopic question, is there any way of stopping numaos from asking me my log and pass every 15 mins or so when I have the page open? its a bit annoying. I want to monitor stuff so I have it open, but every now and then I have to confirm my credentials.
Rauko
Dec 05, 2021Guide
Ive tried everything!! it keeps poping every 30 seconds!
The only things connected to the router are a Laptop PC and a PS5. I acces the modem cia my PC, a regular Lenovo laptop with nothing weird in it, in fact whe nI play I have ONLY firefox running.
Netduma-Fraser
Dec 05, 2021NetDuma Partner
What page(s) do you see it on? When did you first notice the issue happening? Are you connected via ethernet or WiFi when accessing the interface? Are you using routerlogin.net or the LAN IP to access?
- RaukoDec 06, 2021Guide
I see it on the filterin page, but dunno if it happens in others.
Since day 1
ruter, pc and ps5 are all connected via ethernet
Ive tried both ruterlogin and my local router IP, error happens in both, althoug I noticed it does it less frequent when login via de ip number
- Netduma-LiamDec 06, 2021NetDuma Partner
Could you please do the following:
- Remove your device from Geo-filter
- Click the three-line menu and hit 'Resync cloud'
- Once that's finished, Re-add your PS5 to Geo-fillter
- Select 'Choose manually'
Check if the issue continues after completing this process.
- RaukoDec 08, 2021Guide
you mean flash cloud?
