Hate
Dec 16, 2018Apprentice
Error parsing line in ARP table .40
Appreciate the addition of HybridVPN, works very well! Router has been running 2.3.2.40 for about 24 hours without issue but I am getting this spammed in the logs pretty much through the whole day.
Netduma-Fraser
Dec 16, 2018NetDuma Partner
Don't worry too much about what the logs say, they are verbose as they're primarily for developers. You could drive yourself crazy trying to figure out if certain entries can cause issues. ARP table entries are fine so no need to be concerned by that
Hate
Thank you for the reply Fraser.
One last quick question if you don't mind. Is there plans to implement WTFast? I see some files that could possibly confirm this (since .32) but just curious if this was intended or not.
- Netduma-FraserDec 16, 2018NetDuma PartnerI don't know if there are any plans regarding that at the moment
