Rapidvelo
Nov 10, 2018Aspirant
Error: R-App is not loaded yet, please try again in a minute.
Hi there. I’m Receiving this error when attempting to view the network monitor, QOS or even device manager . I did see the other topic where I downgraded firmware to 2.1 but that didn’t solve t...
Netduma_Jack
Nov 11, 2018NetDuma Partner
You might see this for a couple of minutes after upgrading, but it should then disappear (as some items are downloaded from the Internet).
Are you still seeing the error? What version of the firmware do you have?
- RapidveloNov 11, 2018AspirantI still am yes, I downgraded firmware to 2.1.0.4 it worked once and nothing thereafter. I can attempt upgrading to the latest firmware again to see if that helps. Any other suggestions I could try?
- RapidveloNov 11, 2018AspirantHi there
I have upgraded to the latest firmware (
V2.3.2.32) and I’m still receiving the same error? Thank you in advance- Netduma_JackNov 12, 2018NetDuma Partner
Are you using Chrome or Firefox? Please do so if not.
If you are, try using it in incognito mode. Does that fix it? If so, there's an extension (probably security, firewall or adblocker) which is causing problems.
If neither of those suggestions work, do you have another PC you can quickly test with to see if it also has the same problem?
- RapidveloNov 12, 2018Aspirant
I am using Chrome, tried incognito mode without any luck. Tried another laptop as well with the same results, including my iPhone.
I did run the dev console while it attempts to load and it looks like it's reporting 500 errors here are the first two:
POST http://192.168.1.1/apps/com.netdumasoftware.devicemanager/rpc/ 500 (Internal Error)
Retrying rpc assume reboot: com.netdumasoftware.devicemanager::get_online_interfacesPOST http://192.168.1.1/apps/com.netdumasoftware.devicemanager/rpc/ 500 (Internal Error)
Retrying rpc assume reboot: com.netdumasoftware.devicemanager::get_all_devices
