Rapidvelo
Nov 10, 2018Aspirant
Error: R-App is not loaded yet, please try again in a minute.
Hi there. I’m Receiving this error when attempting to view the network monitor, QOS or even device manager . I did see the other topic where I downgraded firmware to 2.1 but that didn’t solve t...
Rapidvelo
Nov 11, 2018Aspirant
Hi there
I have upgraded to the latest firmware (
V2.3.2.32) and I’m still receiving the same error? Thank you in advance
Netduma_Jack
Nov 12, 2018NetDuma Partner
Are you using Chrome or Firefox? Please do so if not.
If you are, try using it in incognito mode. Does that fix it? If so, there's an extension (probably security, firewall or adblocker) which is causing problems.
If neither of those suggestions work, do you have another PC you can quickly test with to see if it also has the same problem?
