seifer
Dec 06, 2018Aspirant
Ethernet access to local devices on network very slow but Wifi fast
I have just gone from a FritzBox router to a brand new Netgear XR500 with latest firmware. The internet speed for devices on my network both ethernet and WIFI is great however when I try to access so...
seifer
Thanks for your replies.
Firmware Version V2.3.2.32
DumaOS Name A7Legit
The modem is a called ONT which is the standard modem given for fibre access in New Zealand. Here's some more info: https://www.chorus.co.nz/q
No switch used, only plugged in directly from an ethernet port from the PC to router. Router is brand new from a reputable store
Netduma-Fraser
Dec 06, 2018NetDuma Partner
Weird that it only affects wired connections as you would expect something like that to affect both. The only thing I can think of would be to untick Disable IGMP Proxying in WAN Settings. Other than that I would too advise contacting Netgears support.
- seiferDec 06, 2018Aspirant
Thanks for your suggestion, unfortunately it didn't work (actually made it so I couldn't access the devices from WIFI either). I'll contact support.
- Netduma-FraserDec 06, 2018NetDuma PartnerSorry to hear that, keep us updated on your progress with the ticket.
- seiferDec 14, 2018Aspirant
NetGear phone support are hopeless I'm afraid. Returning the unit for a refund.
