BruceFloyd
Apr 10, 2021Aspirant
Ethernet Connection
My "Nighthawk XR1000" router will not recognise the ethernet connection to my Foxtel iQ4 box. It will connect wirelessly, but not by ethernet. Could somebody please provide me with a solution.
Apr 11, 2021Guru - Experienced User
does any other device have issues connecting via ethernet?
Did you check with foxtel about changing its internal settings?
BruceFloyd
Apr 11, 2021Aspirant
Thank you for your reply.
All my other devices, Samsung TV, Apple TV, recognise the modem. I have tried a new ethernet cable, and also tried all 4 ethernet ports. All devices operated on the old iiNet modem. It appeards to only be the Fox1Q4 box that is having problems.
It will connect and operate on WiFi, but not ethernet.
Incedently, the panel at the top of this page titled Model, does not list the XR1000.
Cheers
- plemansApr 11, 2021Guru - Experienced User
the XR1000 is a router
What actual modem do you have?
- BruceFloydApr 12, 2021Aspirant
The supply to the Router is by ethernet direct from the NBN fibre optic box.
- Netduma-FraserApr 14, 2021NetDuma PartnerIn WAN Settings on the XR toggle IGMP Proxying then reboot the router/box and see if it works then
