Mark9816
Jul 17, 2020Apprentice
ethernet plugged in question
I have my ethernet for my pc plugged in to port 1 but on the front the light is light under port 4 and it dose this for all ports nothing maches up? Plus my pc gets a oreange light and my ps4 gets a white light why??
- Netduma-FraserNetDuma PartnerThe port experience you've described was present on the very early production products, it is purely aesthetic and will not affect the performance of the router. The orange light means that either the connection is limited to 100mbps - most likely due to the ethernet cable used or that it's not using data over that limit at the time.
- Mark9816Apprentice
Thanks
