Sorrow's avatar
Sorrow
Follower
Jan 27, 2021
Ethernet switch causing lag
Since I have installed my switch(GSS116E) I notice my connection is a bit more choppy depending on the device so the PS4pro can get really bad lag and since I mostly play fighting  games this is a problem I do have some of the consoles connected directly to my router and those seem to have no issue but that only has 4 ports and in my house we have a lot of devices I actually need to upgrade the switch to one with more ports soon, is there anyway to see if there is indeed lag being cause by the switch also is there a way to fix it?
  • schumaku's avatar
    schumaku
    Very unikely the switch does add reasonable lag. Much more likley there are other devices on the other 14 ports causing traffic...
  • I'd suggest posting this over in one of the sub-forums for Netgear switches, you should get the assistance needed over there!
