toxicpanda
Aug 19, 2019Tutor
Ethernet Switch getting throttled
So i don't understand why this is happening and never had this issue on my old Asus AC3200. so i get roughly 400+mbs for virgin media in my area. now on wifi it's perfectly fine ill get near that spe...
- Aug 21, 2019
Ok, thanks for letting us know. Have never seen this kind of behavior and presume something in the switch maybe got hung up on something and needed to be power cycled and disconnected. Keep an eye on it. If it happens again, I would change out the switch for something better.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
toxicpanda wrote:Ok so here are my finding. So for some reason after doing the unplugging of everything connected to the switch the speeds seem fine (Currently) for how long i have no idea, all the cables i use are cat 6 so i know they should be fine, when looking at the XR500 the light is white so that means it should be gigabit right? looked at the switch and some of the light were orange which would suggest it wasn't giving out the gigabit speed?
2 PCs connected to the switch.
https://pasteboard.co/ItHEqeV.png
1 PC Connected to the switch.
https://pasteboard.co/ItHFjXy.pngLaptop Connected to the XR500 from the Switch cable
https://pasteboard.co/ItHFYuS.png
After turning the switch off and on, removing all the cables and placing back in the same cables
https://pasteboard.co/ItHGbFd.png
Thanks again as normal :D
Aug 20, 2019Guru - Experienced User
Just curious, if this switch is the possible cause of what your seeing. Need to try this with out the switch in the mix, if possible.
Netduma-Fraser
Aug 20, 2019NetDuma Partner
As above see if without the switch it works as expected. Also are you using a managed switch? If so this might make sense as when you connect the second device its 'QoS' kicks in. If it is managed are you able to turn of the QoS on its interface?
- FURRYe38Aug 20, 2019Guru - Experienced User
Its a un-managed switch so it shouldn't be causing any QoS issues.
Only other thing that could be causing problems is it does have:
- ENERGY EFFICIENT: Designed to optimize power usage lowering its cost to operate. Most models are compliant with IEEE802.3az Energy Efficient Ethernet mode.
Thought is makes NG Orbi systems problematic, I wouldnt' think it would effect and XR router. Anthing is possible.
Testing with out the switch should give results either way.- Netduma-FraserAug 20, 2019NetDuma PartnerSorry I missed that! That could be it as there were issues long ago with modems that used energy efficient ethernet.
- toxicpandaAug 20, 2019TutorRight I might sound stupid but should I keep the switch ethernet plugged in when I do this or do you mean unplug the cable from the XR to the switch to see if that ethernet cable is the issue?
I'll check the power saving thing also!
I'll put the results tomorrow :)
Thanks a bunch
