Gimli
Apr 10, 2020Tutor
Exchange xr500 for xr700
I have a netgear xr500 worth exchanging for netgear xr700? Thanks
- Apr 15, 2020
Thank you!!!! Topic resolved !!!!
Netduma-Fraser
Apr 15, 2020NetDuma Partner
You're welcome! To answer your questions:
1. Well you don't have gigabit or above internet so it wouldn't increase your internet speeds. If you were to use a SFP enabled PC with that port then you would have a much faster local network between the router and PC. So for example if you were to use Plex then you could upload a movie from your PC to the router HD much faster than if you were to use a normal LAN port.
2. Yes
3. No not that I am aware of and would breach your warranty if you were to open the casing.
2. Yes
Gimli
Apr 15, 2020Tutor
