CoolestJake
Apr 28, 2022Guide
Exspress vpn not working on xr500 router
Hello, so I just got the exspress vpn. I looked up how to connect to it on the nighthawk xr500 router and it said to go to hybrid vpn and then vpn then advanced put the username and pass in and then t...
- Apr 28, 2022I figure out my problem. I accidentally deleted a letter on the config file. So I redownloaded the config file compared them and found that a letter was missing so that was my fault. So now it work. sorry about that.
Netduma-Liam
Apr 28, 2022NetDuma Partner
Have you added the devices that you want to route through the VPN in the 'VPN Traffic' panel on the right?
If not, add the devices you want to VPN and then check again.
CoolestJake
Apr 28, 2022Guide
