CoolestJake
Apr 27, 2022Guide
Exspress VPN not working right on xr500 router
Hello, so I just got the exspress vpn. I looked up how to connect to it on the nighthawk xr500 router and it said to go to hybrid vpn and then vpn then advanced put the username and pass in and then t...
- Apr 28, 2022I figure out my problem. I accidentally deleted a letter on the config file. So I redownloaded the config file compared them and found that a letter was missing so that was my fault. So now it work. sorry about that.
michaelkenward
Apr 28, 2022Guru - Experienced User
CoolestJake wrote:
Hello, so I just got the exspress vpn. I looked up how to connect to it on the nighthawk xr500 router ....
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- CoolestJakeApr 28, 2022GuideI figure out my problem. I accidentally deleted a letter on the config file. So I redownloaded the config file compared them and found that a letter was missing so that was my fault. So now it work. sorry about that.
- FURRYe38Apr 28, 2022Guru - Experienced User
Enjoy. 📡
