CoolestJake
Apr 27, 2022Guide
Exspress VPN not working right on xr500 router
Hello, so I just got the exspress vpn. I looked up how to connect to it on the nighthawk xr500 router and it said to go to hybrid vpn and then vpn then advanced put the username and pass in and then t...
- Apr 28, 2022I figure out my problem. I accidentally deleted a letter on the config file. So I redownloaded the config file compared them and found that a letter was missing so that was my fault. So now it work. sorry about that.
CoolestJake
Apr 28, 2022Guide
Apr 28, 2022Guru - Experienced User
Enjoy. 📡
